Eats shop
- Aug 22, 2019
- 79
- 23
- 8
- Location
- Australia
- Vx 2002 calais
Good morning all,
I've been having problems with my 2001 vx Calais ecotec.
The problem occurred 4 days ago where it randomly stalled in my drive (thankfully)
I needed to go out an hour later started easily, once warm it stalled and started a minute later. It contained to stall at low Revs so I was shifting between 1-3 (auto) it seemed to work but then stalled again.
I've still been using it to get to work the past four days some 50kms each way.
So far I've pulled the coil pack tested all with multi meter all seems good.
I've done the bridging technic for the engine light as it comes on and off at times.
Code flashes.
10-1-2-2
10-1-2-1
I'm going to clean the ICU a clean, the Air flow sensor and throttle body.
Could it potentially be the crank angle sensor?
I've also disconnected the battery for a day and no luck.
I'm kinda lost to what this might be.
Any help is really appreciated!
Thanks!
Code flashes.
10-1-2-2
10-1-2-1
Thanks!
