Need some tips on a VT diff swap
URBTN
Ferntree Gully
VT Executive Series 1
Just looking for some tips.
I want to swap my noisy vt diff for a lsd diff and need some tips on what the best lsd diff is to put in and is it just bolt on or what??? can somebody help!
Cashman_309
VTII Calais
Any diff from an IRS equipped VT will be a straight swap. If you get a diff from a VX-VZ it will bolt in fine but you will need the yoke that connects to the tailshaft to be changed out with a flange.
Not a big job to have the yoke swapped for a flange, just call your nearest diff shop.
Tones
Donating Member
47
SA
VX SS SERIES2
And put some decent oil in once changed over.
Tones
Donating Member
47
SA
VX SS SERIES2
URBTN
Ferntree Gully
so if i get a lsd diff out of a vt ss it would bolt straight in?
Cashman_309
VTII Calais
thanks for your help cashman. can you sugest anywhere to buy it from? should i go to the wreckers and get one or try my luck on ebay or gumtree?
eBay and Gumtree are your best bets but if you scour the various holden forums out there, it can only help your chances.
Try get one with 3.46 (or higher) gears if you can, gets better acceleration
URBTN
Ferntree Gully
ok thanks for the advice. do i need the whole diff housing or just the diff centre?
Cashman_309
VTII Calais
The entire diff...
IMO its a professionals job to change out the centre's.
If you plan on going to the trouble of buying a centre and having it installed, just go buy a truetrac or a kaaz centre and have it assembled into your housing at a diff shop.
