MAS_614
- May 27, 2009
- 111
- 0
- 0
- Location
- BRISVEGAS
- vs executive II
hi all ive just hooked up my amps (kicker zx750.1 powering 2 12" kicker cvrs.. jl audio 300/4 powering 2 sets of polk audio mm651)
my problem is when i first tuned the ignition i had no power to either amps so moved the wire around on the battery terminal and viola power to both amps and everything working well except my subs wernt going although there was power to the amp and was on,
so i unplugged the battery terminal to try sort out the subs and when i connect the terminal again no power ive moved the power to 3 diff points on the terminal but none seem to be giving me power
i have no idea what is going on the fuses are not blown and there was power b4 so why not now?
any help pls
ps i have a 300amp fuse near the battery and a 100amp fuse from distro block to jl audio amp im going to change the fuses to lower amp fuses on the wknd as i only need a 120amp near the battery and 40 amp b4 the jl audio amp but these are the fuses that came with my wiring kits so yer, and i dont have or have access to a volt meter either
any help pls
