[Alloytec] NOS on alloytec
Discussion in 'V6 Development And Modification' started by BrentVE42, Nov 7, 2010.
  1. BrentVE42
    BrentVE42 New Member
    Mackay
    VE SV6 Commodore
    Has any 1 put NOS on there VE alloytec. if so can you let me know what other mods you have done and is it worth getting extractors and hi flow cats as i am getting a 2.25" xforce system and cpr6 manifold
  2. VT-565
    VT-565 New Member
    QLD
    VT
    If you go back to basics, Nitrous is another form of forced induction, installing a better flowing exhaust system would be highly recommended
  3. BrentVE42
    Mackay
    VE SV6 Commodore
    so would 2.25 be enough or 2.5
  4. VT-565
    VT-565 New Member
    QLD
    VT
    Is that a single or twin system?
  5. BrentVE42
    Mackay
    VE SV6 Commodore
    Twin. What other mods
  6. General Xander
    General Xander Epic
    Bacchus Marsh VIC
    '96 VS Executive 3.8L
    if its a twin go with 2.25
  7. BrentVE42
    Mackay
    VE SV6 Commodore
    ok so should i do any internal stuff or will it hold up to it
  8. VT-565
    VT-565 New Member
    QLD
    VT
    Tuning is a big key here.
    Nitrous gets blamed for melting pistons too often, when in actual fact, its because there was too much timing or not enough fuel in it.
    Remember, it is just like adding boost, fuel is what is making your power. Keep that in mind the whole way.
    The standard internals should handle an easy 50-100hp worth of gas, once again, the tune is what will keep it alive.
  9. BrentVE42
    Mackay
    VE SV6 Commodore
    yer is it worth upgrading the fuel system and if so what should i be doing to it ?
  10. VT-565
    VT-565 New Member
    QLD
    VT
    There are a few blower kits to go on these with stock systems, so the fuel system will be right to a certain point, depends how much gas you want to run.
    Very easy to keep going for more jet then all of a sudden you're up **** creek.
    You should get it on a dyno and check out what your fuel system is doing.
    Pump and injectors will be first on the list though.
    If you decide to run a wet shot, then you may very well be able to keep your injectors and just upgrade your fuel pump, providing you're not using a seperate tank for fuel to inject with your gas.
  11. BrentVE42
    Mackay
    VE SV6 Commodore
    What are the brands of the kits. i am getting the kit off my tuners car with the dyno and it is a 100hp kit not sure if its a dry or wet kit but
  12. db_notso
    db_notso diagnostic technician...
    sunshine coast, qld
    vt v6, mods(susp brakesetc...)
    you run nos without a tune and say goodbye to your motor
  13. BrentVE42
    Mackay
    VE SV6 Commodore
    i figured mate
  14. db_notso
    sunshine coast, qld
    sounds like you need to start out smaller then work your way bigger?
    you know get exhaust intake tune then look at your options wether nos or not
    consistincey always wins thgese days
  15. BrentVE42
    Mackay
    VE SV6 Commodore
    yer im getting pacies hi flow cats 2.25 twin xforce, already got an otr for it and now getting a stronger clutch and flywheel kit and a ripshifter. as i am on my p's i cant do much but with this nos kit it can be hiddden away so i can just use it at the strip. and i plan on putting a twin turbo kit longer down the track but thats to obvious. i just want to do things that will be needed for when i tt it.
  16. db_notso
    sunshine coast, qld
    your allowed to have nos fittings but you cant have the bottle or switch in the car (technically but wrong judge/copper/executioner and ur still rootded)
    but mods u list good start
    but think about your suspension and brakes if you have big aspirations for street and track in the one car
  17. BrentVE42
    Mackay
    VE SV6 Commodore
    yer them ####ers do what they want.
    well i have superlows allround not really good for the strip but look good and yer just got the standard brakes on it. do you know what a rough cost of them pbr brake kits are ?
  18. alexius
    alexius New Member
    VE 60th anniversary '08'
    hey mate, the x force duel twin 2.25". is it any good, i was gonna buy one but i was told i could go a 2.5' with 2.5" extractors, and it wouldn't have any lag or sound ****, it would make it have a more of a loud sound, is that correct???? please help some1
  19. Dr HaxZaw
    Dr HaxZaw New Member
    R34 GT-T
    did you starting digging in china to get here this late?
