Semaj
- Feb 26, 2009
- 3
- 0
- 0
- VZ Executive
Just purchased a 2005 VZ commodore, and already discovered a problem :
Sometimes when hazards flick on (including when the locks activate them, so this is rather annoying), the right hand indicator stays on solid. Even after the switch is turned off
By the way it sounds, its as if one relay isn't working properly. I hear a two clicking on, then only one clicking off and cycling as they should.
There doesn't seem to be a hazard relay in the fuse box (there's space for one on the fuse map, but no contacts in place). Is the hazard relay in the computer box thing (that i can sort of see, without pulling anything apart, says "____________ control module", in this model?
