Oil Change for a VE 6.0L
CalaisV2
albany
VE Calais 6.0
Hi All
Has anyone here had a go at doing an oil change on a VE L77 motor. I'd like to try it but there is'nt much room underneath. Can this be done with jack stands or is a hoist the only way?
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Jack stands or ramps works.
Just need to get it high enough to put a large tub underneath to drain the oil into.
Smitty
Moderator
Bayside Melbourne
GenF SV340 R8 Tourer, VK race car, ZX12R
a very large tub with oil deflector.... :)
as when you take the sump plug out, oil will be squirting all over your LH front wheel and chassis
if you don't have something to stop that
vr304
Auckland, New Zealand
2007 ssv manual
sounds like they didn't think that one thru when they made the car lol
Smitty
Moderator
Bayside Melbourne
.. the drain plug is on the SIDE of the sump at the bottom
so yes you are correct !
MYVESSV8
Brisbane/GoldCoast
VE 6LT M6
if you use standard car ramps also have some 4"x2"handy to put in front of ramps, if the car has been lowered it will hit the ramps with the spoiler (ss, sv6) will not sure with calais
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
Never had oil hit anything other than the drain pan. It's a clear shot straight into it.
SARRAS
64
Rodd Point Sydney
2017 Commodore SSV Redline 6MT
Shout yourself and oil sucker vacuum pump thingy - its the best investment in DIY car care and it takes the oil out through the dipstick with no fuss bother or ramps. Perfect!
Grennan
Slayer of Stupid Threads
Glen Waverley, Victoria
VE SSV G8 Sportswagon
How do you change the oil filter with that oil sucker vacuum thingy? Either way you need get to the sump because thats where the oil filter is.
Ive never had an issue with oil hitting anything. It maybe shoots 10cm away from the sump? Undo the sump, position your pan, dont undo the filter until the sump plug stream becomes less of a gushing stream and problem solved.
Should be fine to do it with ramps. Just make sure you get ramps wide enough for your wheels.
ozNick
VL Berlina 3.0 Auto
I have never had issues with my aim hitting the pan either, just the dribble at the end sometimes misses.
