What's our thoughts on oil change intervals on cars in storage or driven rarely? I've always changed the oil around 6 to 9 months as I start and warm my cars up at least one a month or go for a spin sometimes. You don't want sludge building up or contaminants, but I'm yet to properly establish a timeline where oil needs to be changed in these situations.
I store a few cars and most only get kicked over every 6 months if lucky and I try to give them a bit of a run to get heat into the seals for the engine, trans and diff plus run the fluids through the brake and fuel lines, air con and coolant hoses but in reality issues always arise over time.
I’ve has problems where brakes have given up the ghost on longterm stored cars and it is one area I give a lot of attention too before driving.
I have a few cars that haven’t been started for years.
I’ve looked into oils before and heard of the 5 to 6 year shelf life rule and I see it this way, if the car has sat for a few years or more you are better off changing the oil then priming the whole system, you have to add new fuel which has a 6 week shelf life so why not new oil at the same time.
The game you’re in you would have primed many an engine to help minimise wear on initial startup.
If the car is being started each month and not driven the oil will survive and stay reasonably clean for a long time but of course you are increasing the chances of failure in many other areas of the vehicle.
If you are starting the car every month and taking it on a run for at least an hour to ensure you get heat soak thru the entire driveline then you’ll have far less if any problems and I have a couple of cars like this and I change the oil once every two years or so.
My procedure isn’t based on science just mechanical sympathy and having seen the problems some of my cars suffer due to storage.
I store the bulk of my cars at mum’s old place out where it’s hot and dry, that helps save the bodies from rust but does increase the speed in which rubber parts perish and it allows me to be able to drive the unregistered ones around the property without worrying about breaking the law.
I then have to clean up the dust, I hate stored cars but I hate selling them even more.
