Brett_jjj
- Oct 16, 2009
- 6,805
- 109
- 48
- Location
- Tamworth NSW
- vs commodore
If I had pics of the other 2 engines youd see that the damage was very similar in all 3 cases.
This discussion has just turned into an experience war... =/
I'm not trying to confuse anybody. But trying to simplify a statement with info that is somewhat miss-leading is wrong. That's how Internet folklore is born.
no....this is a engineering discussion ......there is always a reason......remember the guy who knocked the lobes off his 304 a while back..............nobody is calling anybody a liar.....but some important parts of this story are still missing. Bretts car had a failure - that is fact. Why is the question.
Does anybody know of a diesel engine oil that does not have an api (or similar) rating.
I cannot think of any reciprocating diesel engine oil (so that excludes turbine oil) that would cause a catastrophic failure in one day....
Upon removing and diagnosing the blown engine, it turned out to be that the oil pickup tube was blocked up with sludge, suffocating the engine. Mind you, this engine had performed over 300'000k.
I am having two thoughts on this.
1) If diesel oil could be used in a petrol engine, why would they have diesel and petrol oils?
2) Maybe the VY lady over filled the engine with oil, I have heard you can break a crank shaft from over filling an engine with oil.
I have seen the sumps off a few petrol engines and they have a thick layer of crap in the bottom, maybe the detergents in diesel oil loosen up the sediment and it blocks the oil filter, opens the relief valve and lunches the engine. Only way I could seen an oil lunching an engine overnight.
My uncles Mazda 6 did 60,000K's without an oil change before self destructing because he is stupid. If the poor old mazda can do that mileage before dying then I think it is unlikely the diesel oils viscosity has anything to do with the engine failing.
Edit:
Hmm, Makes my sediment theory more plausible now hearing that. How come you never noticed the oil pressure light?
At the time, I asked myself the same question. The oil pressure light never come on, so the engine was still making significant oil pressure enough to not switch the contact on. The oil pressure switch contact pressure is below 5psi.
