markovr
- Nov 23, 2003
- 3,072
- 252
- 83
- Age
- 62
- Location
- northside brisbane
- Website
- youtu.be
- 07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
If its coming on consistently only when you brake and the oil is full (this is usually caused by low oil level since braking takes the oil away from the pickup in the sump ) you need to probably change the switch first and if it still happens connect a gauge to the sender hole and try to bring it on when you are driving. Sometimes the relief valve in the pump can stick also causing this or a broken pick up pipe sucking air when the level drops under brakes....a clogged one would cause it to happen at other times so I don't think it could be that.
