Oil sender fitting
mr j-man
GC
VH SL/E 355
Im holding a factory oil pressure sender in my hand right now and its a 1/4 NPT without a doubt....this is the size of the threaded port in the oil pump....correct me if I am wrong!!
Better yet do a google search and you'll also find the "correct" sizing.....most aftermarket gauges come with 1/8NPT fitting and then will supply a 1/8th to 1/4NPT adapter.
The only prob with NPT fittings is that you will only get half the adapter threaded into the hole
Deuce
Super Stock
'94 VR SS V8
That is exactly what I was thinking. Thanks J-man. and for all I could tell, yes this is the size of the hole in the pump body.
phear11
39
adelaide
vs 5L Berlina
is there any reason u want to run both. i just pulled out the factory one and put the autometer one in its place, got a tee but it was the wrong one so gave up with that idea and just did it, the ecu doesnt need it and if the gauge is in eyesight u will see it and also hear if its not getting much oil pressure before u do too much damage.
ps take the air intake off and remove the alternator will make your life alot easier if you havnt already.
ari666
250,000 hits
1/8th NPT drillbit size is 8.70mm
1/4 is 11.1mm
3/8th drillbit size is 14.5mm
the sender i have here on my lap is a 28G R 1/8th thread pitch and measures ~9.5mm and the tip and ~10mm at the fat end.
which fit my small block sender hole fine, but i needed a 3/8th adapter for the big block and the 3/8th is a 18G 5/16" pitch, 13.7 to 13.3mm
dunno if that helps, but 1/4 NPT doesnt mean the drill bit size is 1/4"
ari666
250,000 hits
thats the same adaptor as mine:
1/8 NPT to 3/8 NPT, i would swear it.
Cava454
35
Box
VR SS, VZ SS
Oil sandwich plate. Problem solved.
Immortality
Staff member
Sth Auck, NZ
HSV VS Senator, VT s2 Exec, VX Calais II L67
Remote mounted oil filter
Deuce
Super Stock
'94 VR SS V8
I just so happen to have this:
Just need sandwich plate, dash fittings and hoses.
Ari, also measured sender, I think if one was to be making a fitting for this they would be using the 11.1mm drill bit
