alipete
Ban Speed Camera's
- Jul 29, 2005
- 39
- 0
- 6
- VS Executive VY CALAIS
Hey all,
On my vy v6 Calais I'm getting an oil smell inside the cab when I pull up at stop signs also pooped the bonnet and bent over the engine and could smell when parked (hot). I changed the rocker cover gaskets but no luck and I can't see a visible leak and the engine isn't covered in oil. The car is in excellent serviceable condition with only 136k, it's not burning or using oil with no evidence in the exhaust pipe. I sprayed brake clean around the manifolds. The engine oil is clean and using Penerite 10 without issue till last week. I will check closer for a leak with a mirror tomorrow. Could it possibly be a bad pvc and how would I test that? No engine light but will plug in the scanner also tomorrow. Also no milkshake so the inlet manifold should still be ok.
