oils aint oils
carlyboy
VS11 Statesman
I have both a VRII comm. & a VSII Statesman with the ecotec engine.
So many oils on the market now. I thought as a general rule that older cars say pre 1990 needed 20/50 grades whereas newer cars needed something closer to 15/40- but the VS manual says to use a 20/50 oil.
Any thoughts? not looking for an expensive high performance oil just an everyday good qlty one say GTX2 (20/50) or GTX 3 (15/40).
which is the best grade for the VR & VS models?
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
The V6 Commodore motor dates way way back before 1990 and is pretty low tech. I never pay more than $14 for 5 litres of any brand - whatever is on special. Always 20/50 grade. Never had a problem.
POVRTY
building 5L VB TH 400
taree nsw
Wm L98 caprice
high performance engines need good oil. but if its stocker then just some every day oil will do easily. but this is a choice you have to make and feel good with
POVRTY
taree nsw
Wm L98 caprice
the GTX2 20/50 would be perfect
Harvs82
Glen Waverley VIC
MY08 Subaru Liberty GT-B & MY16 VF II SS Redline
I use Mobil HP 20w50 in my VS V6, have done for the past 70,000kms, never had an issue with it. As previously mentioned by others, the manual recommends 20w50, so thats what it gets. I have tried a lighter grade, 10w40 oil, but you can hear the engine ticking away when it is hot, whereas with the 20w50 its quiet as....
carlyboy
VS11 Statesman
Thanks for feedback. So a good brand 20/50 grade would be good for both the VR engine & the VS ecotec?
Harvs82
Glen Waverley VIC
Yep, thats what I would be using. It's designed to use that grade oil from new, so with a bit of mileage on it by now it would be even more suited to it.
WAGON MAN
Gas Sleeper
North Coast , NSW
VX S2 Berlina Wagon with Phreddied bits.
For the VR and VS i would recommend you use Castrol GTX2 (20/50).
kopper69
34
VRII Acclaim
I switched from magnatec to GTX2 and found much better fuel usage. All these people using expensive oils, which are too thin for the commodore. The VR was designed for 20/50, so why would you use a different oil? Especially when the no. of kms is getting up there.
