Overheating help
Pollushon
Boost gives me a bar....
VY SS
From memory it's 10 litres but you can't overfill. Depending on where you live use demineralised water for longevity between changes.
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
Ok it's all done thanks guys I'm running just water through it now, will drain it all back out and re flush it again, then I gotta out the coolant in, will go 50/50 I think what do I put where but and how many litres can I put? Is there such thing as over filling it?
The system holds 12 litres but there will still be a few litres of water in the engine, so you should add 6 litres of coolant concentrate first and then top up the rest with water.
