commodoredave
Can see the break. its about 10mm from the connectorIf you are unsure about where the break is, you can use one of these to find it.
https://www.ebay.com.au/itm/1341791...VTSobbORpi&var=&widget_ver=artemis&media=COPY
The tool in use:
You would apply the same method to the circuit at hand.
You can repair the wire. As long as it’s the same gauge. I prefer crimping with a brass crimp joiner and dual layer heat shrink so it’s sealed from moisture.
You can unpin the plug and fit it to the new wire/s.
Some new split tube and engine bay tape. Better than new.
