sundaydriver
- Jan 9, 2017
- 122
- 6
- 18
- Age
- 44
- Location
- Queensland
- VH 202 Blue 3.3 Vactioner
Recently acquired an all-original '83 Vacationer wagon (3.3 straight 6) from my grandfather.
Garaged for the last 20+ years. Done <50K kms. Minimal work/maintenance done.
First thing I noticed was a vacuum leak. Found the spot (using some carb-cleaner spray) around the base of the carby, in one corner.
I've made some new gaskets (3) and am in the process of dissolving off one that was fossilized to the plastic mounting block (am currently trying ker-o as don't want to go out and buy abrasive pads etc.) I'm hoping it's one of these and not the 2 (?) that sit between layers of the actual carb.
Anyway, there is a small pan, of some type - I assumed to catch drips/leaks of fuel from carby - mounted between the carby and the engine block (actually, its' between the plastic carby mounting block and the engine block). My questions is, is this really needed? It seems like an unnecessary layer that will only increase the risk of leaks, by adding another fail point. As it is, there are 3 gaskets. removing the pan can drop that to two gasket.
Removing the plastic mounting block could drop that to 1 gasket....?
