panel van roof racks
Ryan.mate
ryan
Up North Wa
vy ss sandman 5.7
hey guys,
i need help as to which roof racks would fit/suit the vy panel van conversion as i plan on buying some but not quite sure. if you need a pic use my dp.
i plan on using racks like the rola racks as they are flush and look good
and help is appreciated
cheers
Ryan.mate
ryan
Up North Wa
vy ss sandman 5.7
anyone?
pease guys, need help?
gslrallysport
VZ AWD One Tonner
You'll need to get a Rhino dealer to fit a set. It's going to depend on what you intend on carrying. If you intend on carrying any sort of decent laod, unfortunately it's not going to be pretty, and will required 4 holes cut into roof, with beams coming down:
http://www.rhinorack.com.au/HTMLImages/UteCanopyImages/ute2.jpg
Otherwise you can pad mount. Basically all your options are here:
Rhino Rack - Ute and Canopy Racks
The only one of those options what will give you the sporty, neat looking roof racks will be the track mount, because once the track is on you can install these racks:
http://www.rhinorack.com.au/Rhinoweb/Images/vEnlargeImages/vEnlarge_900005.jpg
Your best bet will be to fine a Rhino dealer who is experienced in fitting roof racks. (ie. NOT your local ARB). Neither Thule, Pro Rack or Rola will really be able to help you...
Ryan.mate
ryan
Up North Wa
vy ss sandman 5.7
okay, so i want the sport look, as i plan on putting a board along the top, my problem is that the rola racks make various amounts of racks, although there all for certain cars, not mine:(
so how do i find one to fit mine?
gslrallysport
VZ AWD One Tonner
Won't be an off the shelf item, it'll be a cut to length style roof rack using standard legs parts that are designed to mount to your canopy.
