Hi Anthony121,
Thanks very much for your help with all this, I really appreciate it.
I've familiarised myself with the car to check for a good amp location and trace the rear speaker wires.
The VE amp bracket is useless on the VF as the space directly in front of the battery is occupied. I'm going to male a small bracket and attach it further forward of the battery so that it's hidden behind the carpet.
The wiring that came with the amp has been disassembled to leave just the amp connector and cables. All I need to do is run addition cables to tap into the rear door speakers. I've pulled the pillar and sill trims off and found a harness plug adjacent the seat belt retractor. Would this be the best place to tap into the wires?
The ground wires to the amp I will connect directly to the body. As for the power wires, where is the best place to connect these?
Just wondering why there are two power and two ground wires provided on the one amp?
Speakers and shelf are in perfect condition but I'll install those once I've connected everything up and made sure it's all working properly.
Thanks again, will keep you updated with the install and perhaps some photos for other members too.
