-vkhg
- Nov 16, 2006
- 142
- 2
- 0
- Age
- 34
- Location
- Geelong
- 2005 VZ SS
To the OP, No Preload as they are calling it is a fancy word for sloppy. It means if you grab the sway bar and shake it or pull it side to side it will rattle / slide. The rubber bushes should clamp the bar tight enough to stop it rattling but loose enough to let it rotate and flex as you drive over bumps.
Replace the bushes yourself, Holden now sells a revised bush which is better than the original sloppy ones, and costs $15 for the pair. Undo both then replace both and tighten up. Will take 20 minutes out of your weekend.
thanks mate, am i asking for 'sway bar link bushes'? never changed them before, not difficult ?
