Please help
Bamboozle
24
Vk202 efi
hi all I have a vk black 202 efi it won’t turn over I found a couple things just need to know what they are so I can order them I’ll post a couple pics
the_boozer
no more VK
51
Shitsville Morwell
hilux
from memory (how dangerous is that) the vk efi wont run with out the coolant temp sensor in circuit.
Lacksballs
www.youtube.com
VK Group C Replica, 1995 VR Sedan
Start with the battery, earths, inhibitor switch (if auto), check all the fuses & the fuel relay, you could jump 12+ to the starter solenoid to see if it cranks.
the_boozer
no more VK
51
Shitsville Morwell
hilux
the solenoid on the throttle body of the vk efi brings on high idle when the aircon is on apart from that it does nothing efi doesn't have a choke. Its a thirsty system , airflow meter or ignition module is about all that fails on them have seen on a few digital dashes taco shorts to earth and earths out coil. Another time I found the ecu full of water.
anf355
victoria
VB Commodore
Do yourself have power, dash? Is this a result of doing any work to the car or engine bay recently.
Is it auto? Could be your neutral switch. With foot on brake, while holding the ignition turned to start. slide the gear Shifter slowly from Park through to neutral and back a few times.
anf355
victoria
VB Commodore
I mean, do you have power
