well i found a little bit of milky stuff undert the cap, stuck my finger in the rocker cover and couldnt fell any cream stuff or anything on my finger,
havnt notacied any steam coming out of the zorst, except the usal coldness in the morning,
ill check the bubbles in the radiator in the morning
the coolant was full when i got my car runnign fine and i notacied on saturday it was low at miniunum, so over two weeks it had dissepreard, so i think it is only a small crack or possibley a small brake in the gasket
couple weeks back i had some problems with missfirng and the CAS, i read on think it was calais turbo that the missfirng caused by stuffed head can cause the block to twist slightly and when you come to fit a new head it wont seal properly and jsut happen again, do you reackon the CAS/missfing could of had enough force to twist the head slightly causing the gasket to leak??
