Type S's suit sealed boxes... Subs have certain specs and if you put the Type S's specs into a box design program, it will tell you that it doesn't suit ported boxes and would be near impossible to make sound good.
Sealed boxes give a smooth frequency response, so they will be pretty much the same volume for most of the frequency range you'll play. They get quieter the lower the frequency, but the box size will determine how low that is.
Ported boxes allow you to "tune" the box to be loud at a certain frequency, so you can make it loud for midrange bass like rap and stuff, or make it peak down lower so it has a flatter response than a sealed box. But there are many things you have to take into accoutn with a ported box, like group delay, which is basically how quickly the sub will react to the music. A low group delay number is good, it will sound like a sealed box, but a high group delay will make it sound like it's lagging behind your speakers.
The Type S will have a high group delay in a ported box and will sound laggy.
Also, most rap and stuff which seems like low bass is actually around 35-40Hz... Not low at all.
