Okay, I have to ask a question here.
I was always told, if you want to figure out an approximate power level with you boost, to take your standard power, divide it by 14.7 (14.7PSi = 1atmosphere pressure) then add on what ever PSI you want to run to 14.7, and multiply the number you just worked out before.
Now the same works in reverse if you want to know the approx N/A power.
So I took your 246.6KW, and divided it by 22.7. Which is equal to 10.86 approx (rounded)
Now, I multiply that by 14.7, and get 159kw...
So. Did your car magically make more power then it should have standard? (12KW is a fair margin of difference from standard)
And isn't that power output at the rear wheels also? So we take into consideration normally a 30% parasitic loss through the driveline, but today, we'll take only a 20% loss, which will work your fly power out to be 182KW.
So if your dyno graph is correct and at the rear wheels, then your motor standard, made 182KW or more (As I didn't factor in the problems due to heat from the turbos etc) which, is 35KW more then standard for a VS Ecotec...
So, can you explain what mode the dyno readout was in. As for company purposes, dyno graphs are meant to be done in SAE mode.
And then, can you verify why, or how, your car appears to make more power then it should.
In regards to my part up the top with how to estimate new power once boosted, you then have to lower that expectation due to heating of the air which will rise pressure etc etc. Hence, as we work through, we'll find your NA power should be higher then I figured...
I'm struggling to see, where, or how it made that much power standard.
