Johnathan1111
- Jan 28, 2019
- 110
- 8
- 18
- Age
- 27
- Location
- Sydney
- Holden ve ssv
No I don’t have a catch can but I do have an otr ( no tune ) I put on a couple of months ago, I taped a new hole in the back after the filter to place the PCV hose, ile reset the fuel trims and see how it goes , only problem is now it only shows that bank one is running lean so I’m assuming the other codes might have been old left on the obd2, so it could be possible the after cat o2 sensor is faulty also caused by the massive exhaust leak I had on that side for so long, the car is so confused and so am I, I checked all the hoses and the Solinoid and the map ( I cleaned it while I was at it ), still a bit stumped on what it could be, if it was a fuel filter I would assume the whole car wouldn’t run right same with fuel pressure, I should check the injectors it’s been a while, they had some dodgy earthing problems with a frayed earth cable a while ago that I fixed on that same side. It looks like I’m going to have to go to an exhaust shop and check for leaks then change the 2 rear 02 sensors, can’t hurt ( can only the pocket haha) it’s about the only thing left to do after checking every nook and cranny,
