problems with my vt, battery dies
nathan78
renmark SA
vl, vt, vx
have asked a few poeople regarding my problem, every 2 or so weeks my battery goes flat, ive replaced the starter motor as apparently they sometimes fault and drain power, ive also checked my voltage on the alternator and it 13.9, i dont know where else to look for reason for the problem, any help would be greatly appreciated.... cheers nathan
GM GEN3
GM GEN3
S.A
legs ATM
Had the same problem a week ago once running it was running 14volt but thou the day it would go dead flat had to keep jump starting it turned out low water in battery put water in and the it died best bet check the water if its low your cell's would be ####ed you might need a new battery mate
1dvsbstd
Perth Australia
VE SV6 SERIES II 2016
you need a new battery.. ive had this problem before
pablo
Donating member
Was a 1997 vt v6 wagon
If you recon the battery is OK, take off a battery terminal and check for a power drain by hooking in line a multi meter with a 10amp setting. Could be anything from a boot lamp stuck on, to an after market car alarm, stereo amp, or what ever, quietly sucking the power.
Could also be the start of one of the alternator diodes playing up.
FstStig
Diagnostician
Central Coast, NSW
2010 VE SV6
Agreed, Check your battery cells first, top up with water if they are low and clean off any battery acid around your terminals, with hot water.
