someguy360
- Jan 29, 2011
- 4,156
- 6,759
- 113
- Location
- The Shed
- Various
Yeah I could just be unlucky and both regs be bad, and maybe removing my original one just upset it enough that it died completely.It could be both FPR's are bad. If they've been sitting dry after a whole life in fuel the rubber diaphragms probably aren't happy.
You could try putting a clamp on the return line and then see what it does.
On the V6 models the pump is wired through the oil pressure switch, are the V8's the same?
I tried to clamp the return line, it wouldn't start at all when I did that.
I believe the V8's are the same however I believe it was an additional circuit for if the fuel relay died it would bypass to that circuit. However mine doesn't run an oil pressure switch and hasn't for years (I run a gauge and a temp sensor instead). I would test it however I wrapped all that wiring up when I redid the engine loom as I didn't need it anymore. However the car was starting no issues after the rewire without that wiring there.
