Hey fella's, back finally..!
Picking up where I left off, all those moons ago, there's not been a hell of a lot of progress, but none the less...
Basically all this stuff has taken place over the last 6 months to a year/when I was last on here..
These are the old and new bits for the front drivers side lower part of the cab, where the front guard bolts on pretty much..
This is the section in question, didn't look too bad from the outside, but knew from the other side there'd be cancer in there.. The floor pan was only being held in by my sisters fiance` (at the time, now husband).. All the 'inner' panels were rust treated, primed with a zinc rich weld through primer..
Both front floor pans in, and trans tunnel repaired, just needed to add in a filler strip as you can see on the drivers side..
You can see the repaired section in front of the new sill, not quite up to BlownV6's quality of work,
but pretty good for me, can hardly tell it's been repaired..
Another shot from the inside..
The passenger side, it was finished a while before the drivers side just never really put a pic up..
From the outside, passenger side..
All four floor pans finished, sill - lower inners and complete outers finished, front lower sections finished, almost, I think there was a bit more to go on the drivers side rear quarter..
Those rear cross member pieces (where the seats bolt too) were stupidly spastic. Should have just cut them out with the floor pans, then re-welded them in, instead of cutting the old floor pan out in two pieces..
So after the lower sections were complete we figured we'd get it up on some trestles, with the help of my brother-in-law it was easy (he made them!)..
That's about the time the Senator got stolen/parents house robbed, so while waiting for the insurance money I bought a sketchy old rodeo, 1996 model, turbo diesel.. Got it cheap because "the tray mounts were broken off the tray"
Turns out the tray mounts were snapped off the chassis.. :hmmm:
Saturday arvo/Sunday shonk at work, used the fork lift to make things easier.. Had to remake all the mounts on the tray as well as adding a length of 'c' section along the rear of the tray for strength..
Those mounts were snapped clean off, so we added a 6mm fish plate for reinforcement, and welded it back together.. Again, brother-in-law did...
Then I made the best/worst decision of my life, bought a house, with a good size back yard, big enough for at least a three car shed/garage in the future..
So there went most of the insurance money from the Senator, setting the house up, legal fee's etc..
But ultimately good, cause it gets the Ute out of the weather..
Which, ultimately gave me the excuse to finally get the cab blasted, because it could be kept out of the weather..
That Ute's slowly paying for itself..!
Which then led to me cutting the cowl panels off, already knew there was rust there, didn't know how bad but. Passenger side..
Surprisingly the rest of the cab is pretty bloody good, the roof looks pretty much rust free, but it looks like there were a few dance parties on there from time to time. It's definitely not flat..
Repaired Passenger side inner cowl, basically just cut out the old, and made a replacement panel up, in two sections, as it was too hard to get all the curves/bends in it in one piece..
Just as things were moving along smoothly, there had to be something to break the rhythm.. I had received HZ/HJ cowl replacement panels, not HQ items, which turns out are hard to find the complete unit..
Decided to just chop them up and use only the outer sections of the new panels, as the original one is rust free apart from a little towards the outside of the car..
Then, I needed to see some 'progress' being sick of rust repairs, I decided to seam seal and spray up the underneath floor pan with under body deadener off the schultz gun, used the paint-able version, not the tar like cheaper type..
And decided to give the rear section a spray with it as well, to help prevent stone chips and try and cut down on a little bit of road noise.
It can be painted over, which I'm thinking I most likely will paint this section, down to the floor pan, but either way it will be covered by the head board of the tray so it really doesn't matter..
Drivers side, inner cowl section, wasn't too bad, I wire buffed it then flapper'd it, then rust treated it, and that's how the inner panel still sits today..
Figured it has been there for like 30 years and it hasn't rusted through, it should be good for another 10 or so..?
But wasn't happy with the start/lower bit of the 'A' pillar.. That infill piece is double thickness where I'm holding it, to match up with the factory panels..
And not sure what's the go with my finger, but it looks like it's an inch long? lol, its not really..
Welded in and smoothed, and primed. The dark line in the crease of the pillar is just a run of primer, too heavy handed, lol.. Have done the passenger side like this too, but can't seem to find a decent after pic, will get one eventually..
You can sort of see the back rest area I've half sprayed it with deadener as well, just because I had half a can left from the floor and didn't want to waste it, eventually it will all be done, once all the rust repairs are done (the inside of the cab) 100% seam sealed, and deadened, even up under the dash..
If I had my time again, I would probably just cut the entire floor out and fab up a complete new one, it was such a PITA to work around all that shitty metal/curves etc. Would've been done in half the time and probably cheaper if we started from scratch with a box section framed/flat sheeted floor. But this way looks almost factory and be harder to pick once it's all "said and done."
