Question Time
Brysha89
34
Melton,Victoria
WM Statesman L98 6.0ltr
So i am wondering if a l67 overheated would the block still be ok? i dont care for anything other than a block. as there is one for sale atm that was removed due to overheating and thinking of getting it only has 178k on engine, there is no balancer but the flex plate is attached could i rotate that to see if the crank is ok?
losh1971
North Tas
VE Series I SS Ute
Depends how hot it got. I have seen a Ford inline six with a warped block, might not be so much of an issue with short V6 engine. It would want to be pretty cheap before I'd part with my cash. $70 - $80 it might be ok. The issue with excessive heat is the rings can lose tension.
Brysha89
34
Melton,Victoria
ok ty it was $100 on facebook market seems too shody so i took a miss and didnt get it
Brysha89
34
Melton,Victoria
im also looking at rebuilding a l36 block into a l67 block ik pistons and conrods are different but want to do it so what do i need to get to basicly rebuild bottom end ik cranks are same and can get that for less than $500 brand new is there a list somewhere on this forum someone can point me too or if you know would like a list of parts.
losh1971
North Tas
VE Series I SS Ute
I know you want to do rebuild but aren't the full L67s fairly cheap over there anyway? Rather than mess with turning a L36 into L67 it would be cheaper to buy a low km SC engine, even if you rebuild the L67 i think you will still be in front.
If it was Tas it would be a different story as SCs are fairly rare over here.
losh1971
North Tas
VE Series I SS Ute
I'm thinking if you find a low km L67 you could rering it and replace mains and BEs without even taking the crank right out. These old engines have a pretty good lifespan if you don't hammer them too much.
losh1971
North Tas
VE Series I SS Ute
? losh1971 i dont understand?
What I'm saying is i think it would be more economical to freshen up an L67 rather than buy SC pistons and having to rebore an old Eco engine.
Brysha89
34
Melton,Victoria
ok what if i stay the 9:5:1 compression of the L36 and freshen up just the bearings and crank i heard M90 makes more power on the higher comp and boost kicks in at a lower RPM that with a tune would that work? just to freshen the crank and bearings is about $600 inc derlivery
