Radio module
Toto
77
Sydney NSW australiave
2009 ve ss V8 ute
Hi everyone
My ss ute does not get much use so the battery went flat . I fitted a new battery but now find that it discharges quickly because the radio stays on. The screen says "voice in" .also the aircon does not work. Neither does the 6 cd player
The Auto electrician says I need a new/or used module but is not sure. I don't know what my next step will be but I am looking for a used one.
Can anyone advise the best way to solve the issue?thanks
J_D 2.0
Ipswich
2009 VE SSV M6 on LPG and 2022 Kawasaki Z650L
Hi everyone
You’ve posted this in the wrong forum section so you might not get too many responses.
Apparently people have had luck fixing misbehaving radios by pulling the front fascia off and putting it back on. Apparently its just clipped in and you just pull the front fascia off. I’ve not had to do it myself so can’t advise further on it.
Fu Manchu
WA.
What sort of Commodore is it?
lout
60
Langwarrin Victoria
check with holden that it had the software patch to fix this problem
check door lock actuators are working correctly
panhead
NSW Central Coast
Cars
