M3ZZA
- May 17, 2010
- 224
- 0
- 0
- Location
- VIC
- 86 VL Turbo SL soon to be canary yellow bt1 mock
Hey guys i am planning on converting my rb30e n/a to a rb30et using all standard gear and i just need your suggestions and input.
With intercooler piping would 2.5 or 3 inch be better or would 3 inch be to big and cause some lag ?
Can i run vl turbo injectors with a n/a ecu or am i better off tricking the ecu somehow into thinking its a
turbo ecu ?
Would running standard injectors and ecu on 10psi cause damage ?
Whats the most boost i can expect from a standard T3 or T3 highflow ?
With the n/a auto how long do you reckon it could last with a big transmission cooler and regular servicing ? would a shiftkit f**k it quicker with the turbo setup ?
And final question is will i need to get a engineers or emissions test done in order to stay legit or will it already be legit since they came out factory optioned ? Whats the best way to make it legit ?
Sorry for all the questions.
turbo ecu ?
