rda Slotted Disc Brakes
Umai Naa!!
R.I.P APY-88V :(
39
Sthn H'Lands, NSW, Aust.
www.aus12.org
VR S1 Exec. A4 3.8L
If they're noisey, it means they're working ;)
I've had good experiances with DBA in the past. As mentioned earlier, avoid cross-drilled ones. Great for that extra wank-factor, but they're the noisiest, and are extremely prone to cracking.
EXCESSV
39
Perth, WA
VE SSV
i have the premium brake on my VX R8 that are crossdrilled and they stop the thing so much better and no brake fade.
mine have a slight intermitent squeal towards the end of my braking under 10km/hr but thats because pads are slightly glazed due to previous owner not bedding them in properly.
at the end of the day the cross drilled ones you hear cracking are the cheap ones...a good set will be fine.
but if your upgrading brakes on a VT V6 then slotted is more than enough.
they will make more noise than the standard and a good set of pads will make more dust than standard but its the things you have to put up with for better stopping power.
mine rims dont last a week of normal driving with all the brake dust but i rather clean my rims more often and stop better than have minimal dust and find it harder to pull the car up
6 SLEEPER
syd
VT 3.8 L
i have curved slotted rotors on my vt front and back 100% better than stockys and no noise at all curved ones have a bigger surface erea as you can see in the pic they look good to zinc coated
BOGANV8
I gotta V8 whoot whoot
44
Armidale
VX 02 SS LS1
Are these the ones of ebay :) :) :) :)
