GlennVS
- May 7, 2023
- 18
- 16
- 3
- Age
- 53
- Location
- Oakleigh, VIC
- VS Statesman S2
Hi all, my first post but been reading many posts over the last few months, that has been great and helpful.
I recently purchased a very nice VX Calais, series 2. Part of my upgrading including replacing the headlamp globes (both low and high beam - halogen H1 and H4) and parking globes (T10 wedge type LED) with a whiter light. The previous owner upgraded the reverse lamps to a brighter LED type but the rear parking, stop lamps and all indicator lamps are standard original type.
When I turn on the parking lights and/or headlights, the small red ‘rear light bulb failure’ dash error light comes on. It will not go out unless I apply the brakes, only to come back on again when I lift my foot off the brake. I have checked the owner’s handbook and it states in these circumstances, there is a bulb failure in the ‘tail lights’. I have checked the tail lights are there is no bulb failure. My auto electrician stated the front parking LED’s I installed run on very low amps and this is causing it, as the car thinks there is a globe out. I changed back to the original parking bulbs but made no difference. The diagnostic tool was connected but no luck in removing the error.
Does anyone know the cause of this error and how to remove the red warning light? (other than removing the small globe from behind the instrument cluster, that I really don't want to do). I have tried suggested fixes from older threads but not installing load resistors.
Any advice would be greatly appreciated. Thanks, Glenn.
