Not everyone drives their car likes a grandpa. Some people actually use the accelerator to accelerate (wow, I know right).
Castrol actually do recommend Edge 10-60, as does the owner of Mainlube.
straight from CASTROL - they make oil.
HOLDEN
VZ Commodore/ Calais Series, 5.7 Litre V8 Eng. (2004-2005)
CRANKCASE
CASTROL EDGE
0W-40 A3/B4
Castrol EDGE 0W-40 A3/B4 is a fully synthetic, SAE 0W-40, engine oil formulated for prestige and high performance engines. Castrol EDGE 0W-40 A3/B4 provides outstanding wear protection in performance engines designed to run at their optimum level on lower viscosity oils. Castrol EDGE 0W-40 A3/B4 should be used in engines where maximum efficiency and protection is demanded This product is not suitable for vehicles fitted with Diesel Particulate Filters (DPF).
or CASTROL EDGE 5W-30 A3/B4
Castrol EDGE
5W-30 A3/B4 is a fully synthetic, SAE 5W-30, engine oil. It gives you the confidence to demand maximum engine performance from today's highly tuned four cylinder and latest technology engines, operating with tighter tolerances, requiring lower viscosity and stronger oils for variable service intervals. Castrol EDGE 5W-30 A3/B4 is proven in tests to deliver outstanding oil strength.
or CASTROL MAGNATEC 10W-40
Castrol Magnatec
10W-40 provides instant protection from the moment you turn the key. Up to 75% of engine wear happens while your engine warms up. When the engine stops oil drains off critical engine parts, however Castrol Magnatec's intelligent molecules don’t. They cling to engine like a magnet, providing an extra layer that protects during start-up and beyond. Castrol Magnatec’s unique formulation protects from the moment you turn the key, dramatically reducing* engine wear. Castrol Magnatec’s Intelligent Molecules bond to metal surfaces to make engine parts more resistant to wear and are combined with synthetic technology to provide increased protection in high and low temperature applications, providing continuous protection for all driving conditions, styles and temperatures. Castrol Magnatec 10W-40 is suitable for petrol engines, direct and indirect injection engines, LPG and CNG cars, light commercial vehicles and 4WDs. Meets and exceeds API SN/CF, ACEA A3/B3, A3/B4 requirements. Now with ultra refined molecules for protection you can see, hear and feel. * As tested against the industry Sequence IVA wear test.
Service Refill Capacity: 6.2* Litres.
