Well today I wired the VF for use with a projector batter charger. The Charging port is on the rear of the Spare Tyre bath and all wiring is supported with cable tie stick on pads and double insulated where needed. I also added a in line 10 amp fuse just in case but the way this is wired is the same that I have wired my other cars and the only difference is the water proof spring loaded charger point is under the car not in the inner front guards like the other cars. I decided to put the charging point here due to the location of the battery and connected it directly to the battery away from the current leakage detecting devices either side of the battery.
The Spare wheel fits around the connector with no problems.
Cables running up the top rear of the car and are double insulated where needed and secured where possible.
Double insulation where needed. Notice the in line fuse on the right. Double insulated where needed.
Projector Battery charger on the wall with its power point same as the other cars.
Projector Battery Charger Plugged in and working. Yes spring loaded door keeps the door close when not in use with the help of a Stainless steel spring. The fitting has also been sealed.
Easy job No dramas and no tears. No Bombs Exploding, the Ejection seat did not eject me when I reconnected the battery, no alarm going mad, no flashing lights all I did was connect the POSITIVE first followed by the NEGATIVE and all was as quiet as a mouse.
