Removing T5 G/B VP - Tips
azkwazere
Ahhh Yes, Ahhh Yes....
.....SE Burbs
VP 5-SPD / 24-SPD Racer Hybrid
I have to replace my Thrust Bearing (Throw-out Bearing) in my V6 VP.
I have a very firm grasp on the process bar one bit... what is the easiest way to drop a T5 box by yourself?
I havn't been under the car again since i played with the fork a little bit, how many bolts are there from GB to Bellhousing 4?
I guess the main question is... whats the easiest way to lift it down?
I am this at manily vn_luke as i know he's done it a few times. Will a system of jacks work or is it easier to just "chest" it out? It weighs about 50-60kg from memory so i figure i could just muscle it down onto my chest and then roll it off... unfortantually, it will just be me doing it.
I would like any tips or tricks you guys have found easy for taking it out..and also, putting it back in!
Also, while its out.. i plan on checking the pressure plate for bent fins however, is there anything else i should be looking for? i don't want to remove the clutch assembly so flywheel scoring is out but anything else would be great.
so:
-> How many bolts + locations around the box (and a head size if anyone knows)
-> Tips on removing
-> Tips on inspection
-> Tips on installation
Thanks,
aZk.
stocky
azkwazere
.....SE Burbs
Thanks mike... missed that in my searches.
Cheers,
azk.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
The only difference is yours is a V6, but it's basically the same.
Immortality
Staff member
Sth Auck, NZ
one good mod would be to fit studs (for the bellhousing) if you intend to pull the trans out on a regular basis. that absolutly no good to you however:p
