K
Knux
Guest
Have any of you taken off the clothed trim in the door? Does that just pop out the back of the door?
yer after fighting the door for a while i noticed the white clip found that to be my biggest head ache outta the whole jobmistaken said:3) Trick with replacing the door trim is clipping the white clip in the middle back in first, then aligning the lock rod, then then top trim that runs along the window ledge.. then the rest just pops into place.
vzsv8 said:...gently levering it away from the door, only at the bottom...
vzsv8 said:...I did not cut the Holden speaker connector off, just spliced into the wires so I have the option of refitting the original speakers in case I sell the thing later...
