Repair broken B terminal - Alternator
PIR4TE
Banned
AWOL with Ari
Black Pearl
I received an upgraded 150A 14v alternator in the post but the 'B' terminal has broken off the mounting plate :(
Can this be repaired? Any suggestions as to workaround to make it work?
Dirbatua
AWOL!
S/e Victoria
VX SS Series 2
Seal it back together with JB weld.
Mix it up, put jb weld on it and tape to hold it, leave it for 10-24 hours and it should be good to go.
PIR4TE
Banned
AWOL with Ari
Black Pearl
Ok thanks heaps, will definitely look into this but the one thing that bothers me is the importance of good conductivity at the repair join, being the main earthing point.
Reaper
Tells it like it is.
RG Z71 Colorado, 120 Prado , VDJ200, Vantage
if you braze/weld it conductivity will be as good as it gets
Dirbatua
AWOL!
S/e Victoria
VX SS Series 2
I didn't think it was an earth point, i figured the bolt was the important bit and the rest was just the casing.
either way just find a metal repair mixture that will dry solid, mix up a batch and check it with a multimeter.
PIR4TE
Banned
AWOL with Ari
Black Pearl
Hmmm, I think it's stuffed because the B Terminal post is the main output from the alternator to the battery.
What a waste!
phillmac
Blue Mountains
VE SV6 Sportswagon 2011
Glued some aircraft alloy together. What a pile of horse ****
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Didn't say it was used to bond aircraft alloy (which it wasn't).
And as far as I know, it doesn't meet aircraft structural bonding specifications.
Just said it was used in the industry.
There are better structural compounds available.
But hey, don't knock it if you haven't tried it.
