david dubbo
- Jul 11, 2009
- 220
- 5
- 18
- Location
- perth
- vx gen111 wagon
Ok I'm no guru when it comes to electronics but after reading lots of threads saying it cant be done and others saying it can I thought I would have a crack at it. As I thought I might stuff it up I grabbed one from the wreckers which was also buggered (free)
gently and gradually lift the black cover off it is glued on very well and requires a bit of patients once removed you will see a set of prongs sticking up.
heat these up and apply solder to them. Then wait till the missus is out and heat the oven to 175 degrees c (just hotter than solder melting point) once the oven is hot place the unit on an oven rack plastic pointing up and bake for ten minutes watching for any melting problems. I was very sceptical of this when I read it as I was worried about plastic melting but it was fine it didnt even hurt the silicon gasket on the housing. remove from oven and allow to cool replace in the car and no more lights or inaccurate instruments. This may not work for everyone but it fixed mine and the one from the wreckers so chances are it will. total time to do the whole job was less than 1 hour and that included waiting for the oven to heat up. I forgot to mention I glued the cover back on with 5 min araldite. Thanks to all those that had previously had a go at it and wrote about it this is how we all learn and save a little money. Forgot to mention didnt write how to remove and replace as there are a heap of how tos on the subject.
