I hate power antennas
Can anyone tell me why the replacement mast and rope I purchased from Rare Spares refuses to fit back into the vertical tube that sits upright of the motor? (Car is a VX SS)To get the old mast out, I had to chop the tip off in order to remove it from this tube. I have the the tube off of the motor. That's fine but the mast will not fit from either direction. There is a white plastic piece at the base of the mast which hindered the tube. In desperation, I trimmed this with a knife until I could squeeze this into the tube. However I then found that there is a metal sleeve on the mast which absolutely will not fit the opening of the tube. I think this sleeve is designed to locate the mast within the tube and keep it stable. I used brute force and ignorance to no avail. I'm pretty sure it's the right part, it certainly looks the same as the original I removed.
I am deadset pissed off. I am driving from Sydney to Adelaide next weekend and need the thing working. If anyone can set me up with a complete antenna before next week then I am all ears.
Thanks
