Replacing valve stem seals...
Drewie
East of Melbourne
VX SS (Original owner).
I need to replace the valve stem seals on the VC 202 blue motor, I am going to try and do it with the head still on the motor, I can purchase a small screw down valve compressor that hooks onto the spring and the fitting to fill the cylinder with compressed air, but looking at the manual there does not appear to be much of the valve spring acessable to hook the spring compressor onto, I don't want to go and buy a valve spring compressor only to find there is not enough spring available to hook the spring compressor onto. Looking at the manual there does not appear to be much of the spring showing, the shroud seems to cover a lot of the spring, has any one change the seals on a 202 with the head left on the motor? I know it can be done this way on a lot of cars, my VR was done this way under warranty for faulty seals, only took the Holden guys a few hours to do the job.
DANNY8
Yo Coooornflake!
35
Port Pirie, South Australia
www.kerrbrosracing.com
VK WAGZ 5.0L, GQ Patrol TD42
Get one of these spring compressors...
Just pull ya rocker gear off, fill ur cylinder with air, then chuck the spring compressor over the spring, the top sits on top of the retainer and pushes down on that, and get the bottom hooks around the lowest part of the spring possible, wind it down, remove the collets, then use a razor blade or sumfin sharp to slice the old seal off and remove it, put the new seal down into the groove, put ya collets back in and let the spring back up.
Remember to hit ya retainers first to loosen the collets.
Where are u getting ur air fitting to fit into the cylinder? I couldn't find one anywhere for sale, ended up having to borrow one.
Drewie
East of Melbourne
Thanks for the advice Danny, I now know what type of spring compressor to look for, re the fitting for the spark plug to hook the airline up to, I rang a spare parts mob here in Victoria called 'East Coast Spares' it was the Ringwood store, from memory he said they were around $20 and he had them in stock, was about a month ago he had them so hopefully still available.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
you can smash the porcelain off a spark plug and weld on a stock airline fitting if you want a diy solution
ari666
250,000 hits
