vc commodore
- Jun 18, 2014
- 10,729
- 12,637
- 113
- Location
- Like the Leyland Brothers
- VC, VH and VY
I'm working to get my 2001 VX (260,000) roadworthy as we speak. Mine was worse than yours - showed it to a mate and he said they were VERY picky and most stuff is common of a car this age.
- Rear flex joint
- Centre bearing
- Engine mounts
- Bonnet release
- Wiper washer system
- Lower control arm inner bushes
- Lower control arm outer bushes
- Radius rod front bushes
- Radius rod rear bushes
I managed to fix all of that over a weekend or so, except the engine mounts (yet to attempt) and lower control arm inner bushes - I've removed the control arm from the car today and am up to removing the old bushes. It's a Sunday so no mechanic with a press is open, so I might have to call it a day.
I also had coolant and oil leaks noted but he put (A) which I guess means attention needed.
Don't need a press for the inner radius rod bushes in the control arm.....Cut the old ones out, replace with new 2 piece bushes and all done. Take you an hour from start to finish....That is, with removing control arm to refitting it with new bushes.
