derrro
haha tough
Ok it's bloody obvious - general rule is: Don't sit on the sides of your seats for ages (or let your younger bro do it as he has in mine - GRRR). That said, they are going to get some wear, esp after 5 years and if you have not owned em since new. Here's how to double the lifetime:
1) Undo all electrics on the front seats
2) Unbolt both front seats and remove from ur SS
3) Remove plastic trim from the sides of the seats, unbolt the the back section and remove (the part you recline)
4) You are now left with two base sections. Turn over on a soft surface and carefully unclip the black plastic retainers on the underside of the seat then remove the base seat foam AND leather/cloth.
5) Swap onto the other seat and re affix. NOTE: make sure the metal part of the base is INSIDE the pocket provided for it in the foam, NOT in between the leather/cloth and the foam.
6) Do it all up again and re install.
As you should figure the generally more worn driver's side bolster is now butted up against the centre console, pushing it back into position. The unworn bolster from the passenger side (console side) is now the door side of the driver's seat. Should look ok.
Enjoy and be careful not to stuff it up this time
EDIT: PICS OF THE PROCEDURE ARE COMING THIS WK END!!!!!!
