well i thought the bigger gouge was just part of the machinig process when the holes for the pin were drilled... it doesn't seem big enough to be a clearance purpose to me, but you guys are the ones with experience so im trusting someone has come across these...
pub and rvk you both hav been a big help already thanx again.
the side with the bigger gouge will be to clearance for the rod as it travels up and down with the rotation of the crank. I hope I'm right on this but i'm going to call the larger gouge should be on the inside. I would like to hear other peoples opinion on this cough rvk355 cough.
My engine building experience only relates to using standard piston (which are easy cause they got the notch in them ) i've built plenty of engines but never any with forgies
