B
brentasaurous
Guest
in the manual! haha otherwise it is really simple, i learnt as i went along.
remove the steering wheel
undo the four screws that are on the underside of the cluster
unclip the connections that connect the cluster buttons
pull the cluster out
remove all the screws on the back and i think theres four down the bottom of the front of the cluster
unclip the clear plastic cover
unscrew the four tiny screws that hold the gauge face in place and pop off the needles carefully, you can use a fork if you need but be careful
remove the gauge face and you are now into the guts of the gauges!
