Tranny fluid amount
JCs rocks - one of the best forums around.
If an old thread is still up and valid perhaps it needs to be moved into an archive section (INSIDE vz how-to's).
I have something I bet all you blokes will lurve. I have a VZ 6pd with an L76 and the clutch that goes with that motor (slightly more heavy duty). As I learnt to drive a manual with my SS I thought it might be a good idea to change the tranny fluid. Nice car to learn on hey
So first I checked the specs in the car's user manual. No info about how much to put in.
So I googled it and it came up with the GTO forum in USA. Same tranny so it must be the same? Man I hope so. I need to check something:
Do you refill until the fluid comes out of the reverse switch hole? Can someone let me know how much fluid my tranny takes?
I didn't use ATF DEX 111 but a combo of other stuff (high qual tranny fluid and Nulon additive). Filled up to reverse switch. Now when I am stationary I can hear a hissing sound when the clutch is out. AND a slight loss of pwr. Faaaaark!
