Gunnazz
Donating Member
G'day all,
As the title suggests, I'm having issues with my AC. I was driving to work and about 10 min into the drive the AC cut out, its hast returned since. I have since checked the following,
AC belt is still there although the compressor is not engaging. The compressor clutch relay is working (swapped with fog light relay) The 10 amp AC fuse is ok and has continuity both sides. The AC system still has 100 psi gas both high and low sides. The high low cut out switch wiring has continuity, I'm unsure how to test the switch itself. Of the 2 plugs on top of the compressor only the rear most plug has continuity the front dose not. I'm unsure on were to progress now, Should I continue to look at the plug on the compressor, Is the front plug supposed to have continuity or dose it switch on and off with the AC?
Any help or ideas on were to look next would be greatly appreciated.
The vehicle is a series 2 SSV ute.
