More air is good, but without a tune, not useful. You will essentially just lean out more.Does anybody know how much hp a standard air box will support would modifying the inlet ie making inlet to airbox behind light bigger help ?
I think the ECU’s more capable (ie. than you’re inferring) of measuring the air going in & hence providing the right amount of fuel. Especially as the sensors are after the airbox.More air is good, but without a tune, not useful. You will essentially just lean out more.
Fact is...I never said run lean...I said lean out more. Any change the computer makes is to fix the lean condition. So, you use more fuel, but the outcome is two-fifths of eff-all. It’s a super-common change for every car owner, chasing power.I think the ECU’s more capable (ie. than you’re inferring) of measuring the air going in & hence providing the right amount of fuel. Especially as the sensors are after the airbox.
Reading that back to myself ... I don’t mean you’d get more power from changing the airbox, I mean that it’s not going to make the engine lean-out at all (if you don’t mess with the ECU & sensors that is!).
Yes, I guess so.If that gets anywhere near making sense ...
I know this is veering further off topic, but how does the (standard) ECU setup use the airflow meter if not to drive AFR? Is it secondary to MAP or something like that?any change in airflow in and or out of the engine will cause a change in AFR
