vombil
Hi guys have a VT SS series 1 5L auto with not a lot of history pre-purchase. The car will only start via a bridge on the start relay (under bonnet) - it won't even crank with the key. It does run so it's getting fuel and spark so I presume the security is deactivating?? however when you press the key fob (looks like a new aftermarket shitter) nothing happens - ie it does not activate the door lock actuators nor can you hear an audible noise of BCM click so maybe the fob isn't operational but it is communicating with whatever to start the car I suppose.... or am I bypassing the security if I bridge the start relay to get it to run? any suggestions ? I'm thinking key fob or BCM.
many thanks
many thanks
