Starting issue
DJLNZ
58
Dunedin NZ
VT Clubsport
Hey there car wont start Had starter done up about 2000 km ago Ing lights come on and turn key no go Put Hot wire to starter and away it goes Do the vt 304 have a starter relay if so witch one is it Thinking it could be that Or any other ideas Cheers Its a manual so can clutch start no worries
BlackVXGTS
Melbourne, SE
The diagram below may help you.
When you say "won't start", do you mean it:
  • doesn't crank at all,
  • cranks OK but doesn't start,
  • cranks OK, starts but then cuts out.
Most 304 non-start problems are due to faulty coil, ignition module, hall effect sensor in the distributor, battery, fuel pump etc.
DJLNZ
58
Dunedin NZ
VT Clubsport
will start if put hot wire to starter or clutch start Thanks for that will try replace starter relay
DJLNZ
58
Dunedin NZ
VT Clubsport
hey there stillno go Turn key on ing lights come on but wen turn key to start no joy wont turn starter over Changed the starter relay no change Car runs perfect when clutch started Or a hot wire to starter but turn of it wont start again No cranking on starter motor any thoughts Cheers
lout
60
Langwarrin Victoria
prndl switch or clutch switch if manual
krusing
Melbourne, Bayside
VATS ?
PIM Link ?
Have you replaced the Key Head Recently ?
Have you replaced any other modules Recently ?
When you turn the Key, the Lock Light [on the dash] remain on ?
DJLNZ
58
Dunedin NZ
VT Clubsport
do they have a clutch switch ??? im a panel beater by trade so know a bit about this stuff Can start car with out pushing cluch down But will check Cheers
DJLNZ
58
Dunedin NZ
VT Clubsport
VATS ?
PIM Link ?
no and now will check if lock light stays on Never knew it had one lol will look any help is good help Put car in garage and went to start it aprox three weeks later no go Mate woorks for AA nz here and said about bcm plays up so pulled fuses for aprox half hour but still no go Clutch down drive runs fine go for ride all good untill u stop it
Forcedvp
VT HSV XU8, FORD TERRORIST
Is the ISS still fitted/enabled? Or does it have an aftermarket security system fitted?
  • Like
Reactions: Lex
