Steering Pump. Front shaft removal?
gontix
VR Executive S 3.8
I'm servicing my power steering pump, trying to replace the front shaft seal. It looks to me that I will have to remove the main shaft in order to replace the seal. But I can't seem to work out how. I'm guessing you need to remove whats left of your front pully, and do I need a pully puller to do that? Or is there some way to remove the whole shaft from behind? Cheers..
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
The workshop manual says to remove the pulley with a puller....and then you pry the old seal out and tap new one in.
Hope this helps.
