I posted the instructions below some time ago, when I had my VX GTS, in relation to a similar problem the OP is experiencing. I think it's still relevant for the VE.
Bleeding the T56 Clutch
I have a Textralia X-grip clutch system installed on my VX GTS 427 with a standard master and slave cylinder, and don't have the problems you are experiencing. Having said that, an HD clutch will always be more temperamental in terms of release and smoothness compared with a standard clutch - however, the standard ones won't cut the mustard !!!
I suspect that your clutch is not being bled properly - it's difficult to do with the clutch slave cylinder being installed inside the bell housing. Firstly, I recommend you purchase and install an extended bleeder from eBay - you may get it cheaper from Bursons and other motor retailers. This allows you to easily attach a hose and container to the bleed nipple:
The next thing is very important. I replace my clutch fluid every six months because it becomes contaminated (and black) and I've tried all different methods to replace the fluid and get a good pedal. You need to forget the guidelines you may have seen in relation to bleeding brake lines.
1. Once you have installed the extended bleeder, remove all the old brake fluid from the clutch master cylinder. I use a turkey baster to syringe all the fluid out and kitchen paper and a toothbrush to get rid of any remaining dirt and fluid.
2. Fill the master cylinder with new fluid - I use racing brake fluid but I'm not sure if that works any better than standard high quality brake fluid.
3. Attach a (clear) plastic tube attached to a container, which is located higher than the slave cylinder.
4. Crack the bleed nipple about 1/2 of a turn.
5. Slowly pump the clutch pedal three times.
6. Refill the master cylinder and repeat step 5 until the fluid in the plastic tube is clear. you need to be careful as the clutch master cylinder is rather small and if you pump the clutch more than three times, or forget to fill the master cylinder you will have to start all over again.
7. Once the fluid in the tube is clear, tighten the bleed screw, top up the master cylinder, and you will have a magnificent clutch pedal that has no sponginess and performs well.
8. Be careful when you remove the plastic tube and reservoir to prevent old clutch fluid contaminating you and the environment !!!
